Author Topic: Richw911 Question for you Re temp sensor  (Read 2384 times)
Offline stfc_gti
Re: Richw911 Question for you Re temp sensor
« Reply #10 on: 16 July 2012, 21:39 »
i think rich had his favourites deleted and he's having a melt down
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 16 July 2012, 21:44 »
as above, it's the same as most of the clips in the engine bay, they need a squeeze right at the top which lifts a hook allowing you to pull the plug off
Offline richw911
« Reply #12 on: 16 July 2012, 22:56 »
As said Squeeeeeze  :laugh:
I may have a link somewhere to help you  :grin:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #13 on: 17 July 2012, 00:36 »
LOLOLOL. I reckon he must have 3254262 minimum favourites....With 90% of them being used for this site  :grin: :laugh:
Offline theshrew
« Reply #14 on: 17 July 2012, 08:39 »
No its not got anything like that. I had a quick look this morning i think maybe the plug is broken ( the bit you squeeeeeeze in missing )
Any idea how i can remove without ?
Offline theshrew
« Reply #15 on: 17 July 2012, 09:14 »
Mine is the same connector as in this vid
http://www.youtube.com/watch?v=PE82KM-ikt0
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #16 on: 17 July 2012, 13:20 »
Ah that makes it a bit harder...
You can pop the sensor out still attached though, that should give you a bit more of an idea what you're up against
