Author Topic: DanChave's Flash Red GTI 16V. Engine strip, clean and paint!  (Read 140237 times)
Offline DanChave
Re: DanChave's Flash Red GTI 16V. Engine strip, clean and paint!
« Reply #60 on: 21 August 2012, 10:08 »
Not long till the gearbox is off and that heavy metal disc has 5+kilo shaved off it.....
... that is what your doing right?  :tongue: :evil:
Once the engine is all back together, I will be looking to take the gearbox out, clean, paint, replace bolts etc so I guess it makes sense to lighten the flywheel at the same time :) I have heard of people doing this, but what exactly is the benefit?
Offline Seanl
« Reply #61 on: 21 August 2012, 16:02 »
Less inertia, so quicker revving basically. Some say you loose torque, but I've never seen any evidence to suggest this. I had it done on my mk3 8v, and I thought it was great! People wouldn't do it unless it was benificial. Worth renewing the clutch seeing as the GB is off, and flywheel out too mate.
Offline DanChave
« Reply #62 on: 21 August 2012, 17:24 »
Cool, when the gearbox comes off I'll do that then! I am going to consentrate on getting the engine back together and the car back on the road, let my funds build back up again and then tackle the gearbox :)
Offline LowlifeDubber
« Reply #63 on: 21 August 2012, 18:09 »
Some good work going on here mate.
Have you chose someone to do your flywheel yet?HotGolf on Clubgti is highly rated.
Offline Seanl
« Reply #64 on: 21 August 2012, 18:52 »
Indeed, Hotgolf did mine, abou £80 incl delivery to him att. Nice quick turnaround, and he keeps you up to date with progress the whole way. Highly recommended! :wink:
« Reply #65 on: 21 August 2012, 18:55 »
Did you have much removed from yours Sean?
Offline DanChave
« Reply #66 on: 21 August 2012, 18:56 »
Cheers bud! There should be some good updates in the next couple of weeks :) I hadn't thought about it yet, but if he comes highly recommended then I'll check him out.
Offline DanChave
« Reply #67 on: 21 August 2012, 18:58 »
And how much would you guys recommend removing? Is there an ideal weight I should ask for?
Offline leigh_harty
  • Audi AGU
« Reply #68 on: 21 August 2012, 19:50 »
I had mine down to 6.9kilo on my old 16v and it made a good noticable distance, i was never more than a cars length off my mates vr until the (over 100) vr grunt come in!
http://www.golfgtiforum.co.uk/index.php?topic=134237.msg1207070#msg1207070
Dont lose your dinosaur!
Offline DanChave
« Reply #69 on: 21 August 2012, 20:37 »
Sounds good :) How much do standard flywheels weigh?
