Golf mk3
hardmonkeys
Power Steering Issue.
Topic: Power Steering Issue. (Read 3083 times)
javalin
Re: Power Steering Issue.
Reply #10 on:
13 July 2012, 21:57 »
Shouldn't need to remove the pump unless the adjuster is seized. if so about 6 13mm bolts as said.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
AcidicDavey
Here all the time
Not a VAG Owner.
Reply #11 on:
13 July 2012, 22:25 »
Thanks everyone so far,
I checked today and it seems like there's quite a bit of movement in the belt so it's not correctly tensioned so I can only guess that is the fault, cheers guys!
95 Volvo 480 2.0 Celebration
Golf mk3
hardmonkeys
