Author Topic: Boost  (Read 2589 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: Boost
« Reply #10 on: 13 July 2012, 07:18 »
Mine doesnt unless the engine is under load,
For example flat road in 1st and 2nd would peak around 12-14psi but on a nice hill would peak 16-18psi.
3rd and 4th would peak around the 16-18psi most the time to be honest.
That sounds a bit more realistic, I am also measuring from when on boost as in 0
idle mine is -8psi, boost is as said above
At idle mine is on 18-20 but that is at the bottom of the boost gauge, if you know what I mean. Not sure if that bit is measured in psi though
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Dalo Harkin
Re: Boost
« Reply #11 on: 13 July 2012, 11:03 »
mine goes like this from bottom to top
-18 -16 -14 -12 -10 -8 -6 -4 - 2  0 +2 +4 +6 +8 +10 (1 bar) +12 +14 +16 +18
so at idle its -8 and peaks to around +12 - +14
Offline cullygti
Re: Boost
« Reply #12 on: 13 July 2012, 13:57 »
-8 at idle mine is -20 at idle  :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Boost
« Reply #13 on: 13 July 2012, 14:06 »
gauges should read in hg when below 0 really
Re: Boost
« Reply #14 on: 13 July 2012, 14:08 »
Ahh, so it does, I just looked at mine.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Boost
« Reply #15 on: 13 July 2012, 14:15 »
 :wink:
