Author Topic: Realistic thoughts about AGU stage 2  (Read 37910 times)
Offline jamie1989
Re: Realistic thoughts about AGU stage 2
« Reply #30 on: 06 July 2012, 10:52 »
Awsome. If you get good results I will lean towards having the same side mount.
If not I will have no choice to either build my own front mount or buy the THS one.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Chris.
« Reply #31 on: 06 July 2012, 11:13 »
was getting 192g/s with the k03s on standard actuator, mind you it had a very easy life and only 52k  :grin:
230bhp+ is possible with SMIC although heat soak is bit of an issue and probably would get more torque with a front mount.
How do you see over 187g/s with AGU MAF?
They limit out at 673kg/hr @ 4.9V which is 187g/s
Click For Build Thread
Offline Chris.
« Reply #32 on: 06 July 2012, 11:14 »
Selling all my stage 2 k03s gear if anyone interested.
Offline rolty_gti
« Reply #33 on: 06 July 2012, 11:44 »
whats in the bundle and how much you looking for it mate? :evil:
LCR Decor - Quality affordable home improvements, we also take on commercial work, www.lcr-decor.co.uk free quotes! essex/london/kent and surrounding areas. call lee-07984106950 e-mail-leerolt@lcr-decor.co.uk
Offline Chris.
« Reply #34 on: 06 July 2012, 11:52 »
Everything.  Drop me a pm and can go from there
Offline jamie1989
« Reply #35 on: 06 July 2012, 12:03 »
Also intrested!!
« Last Edit: 06 July 2012, 12:05 by jamie1989 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #36 on: 06 July 2012, 14:41 »
lol you don't have anything I need yet again  :grin:
Offline Chris.
« Reply #37 on: 06 July 2012, 19:23 »
Build another stage 2 AGU.  £1100 and you can take my 250bhp setup - everything hahaha.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #38 on: 06 July 2012, 20:39 »
If only...
Offline Scott D
« Reply #39 on: 07 July 2012, 00:51 »
Have an AUQ bud
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
