Author Topic: Realistic thoughts about AGU stage 2  (Read 38020 times)
Offline daz veedub
  • Operation 1.8t bolf
Re: Realistic thoughts about AGU stage 2
« Reply #120 on: 23 July 2012, 16:54 »
my turbos off but cant get it out out if ya know what a mean to hot now be pissing about with it haha
Offline jamie1989
« Reply #121 on: 23 July 2012, 18:30 »
boost pipe popped off and answers my question about not boosting as normal.
Should I see a difference with the k03s on a standard AGU stage 1 remap?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Chris.
« Reply #122 on: 23 July 2012, 18:50 »
about 160bhp is what mine ran on nicks rollers.
Click For Build Thread
Offline jamie1989
« Reply #123 on: 23 July 2012, 21:09 »
I can feel some improvement however unless I have another boost leak or the actuator is set up wrong which I doubt its still only boosting 14psi.
Before the turbo swap it would boost on a hill upto 18 at times but its not butching over 14.
I can hear something as if its leaking too so my guess it I prob have a boost leak.
Just waiting for my ths intercooler now and get it remapped with injectors and vr6 maf.
Price with R-tech custom map is £190 isnt it? Im currently running their map..
Offline cullygti
« Reply #124 on: 23 July 2012, 21:22 »
no mate it will be more as you have changed the turbo it only applies to 1 turbo going onto stage 2 etc if that makes sense thats what nick was saying before unless he has changed it
Offline Chris#101
« Reply #125 on: 23 July 2012, 22:02 »
stage 2 live custom remap is £290  :cool:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline jamie1989
« Reply #126 on: 23 July 2012, 22:14 »
Arhh man I thought it £290 for aum's etc
But as im running stage one R-tech remap already on a AGU it would be £100 cheaper  :sad:
I thought as the aum's auq's are vvt or have electronic throttle bodys and map sensors they werent as easy as agu's.
Offline cullygti
« Reply #127 on: 23 July 2012, 22:16 »
no mate it dont work like that if you was mapped on a ko3s then it would be cheaper if you were mapped on ko3 and then going back with ko3s its full price just give nick a shout to confirm for def tho mate  :wink:
Offline jamie1989
« Reply #128 on: 23 July 2012, 22:22 »
Arhh pants itl be worth it I suppose lol
 :evil:
Offline jamie1989
« Reply #129 on: 24 July 2012, 14:36 »
So after talking to the R-tech boys iv bummed out on remapping the car with the injectors and vr6 maf   :cry:,
However the car is booked in August 3rd @ midday with the following specs -
Engine - AGU
K03s with forge actuator (yellow spring)
Forge 007p (yellow spring)
3inch turbo back with decat
THS front mount
Creation sports tip and 5 piece boost pipes
Standard bosch maf
Standard injectors.
The car will be booked back in at a later date to map in the injectors and maf I just cant afford a week away without the car atm and getting 2x lifts up there and back from Sunny South Wales  :sad:
Updates will be done shortly  :cool:
