Author Topic: ko3 turbo  (Read 4998 times)
Offline jamie1989
Re: ko3 turbo
« Reply #30 on: 05 July 2012, 20:07 »
How much did you sell them for?
I could be intrested.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Dalo Harkin
Re: ko3 turbo
« Reply #31 on: 05 July 2012, 20:14 »
think they'd be the wrong spray pattern. i feel i right prick for selling them you, didnt no what engine code i presumed agu with youy fitting the ko3s, i will ring a few mates tomorrow see if i can get you the s3 injectors and will swap them with you for your yellows.
Its not your fault mate, dont worry about it ill try and source some S3 ones.
if anyone you know wants them/swap let me know
Offline jamie1989
Re: ko3 turbo
« Reply #32 on: 05 July 2012, 20:27 »
Me lol
How much do you want for them?
Offline Dalo Harkin
Re: ko3 turbo
« Reply #33 on: 05 July 2012, 20:51 »
Only ones on ebay are starting bid 40 and 5 postage so make me an offer  :wink:
Offline jamie1989
Re: ko3 turbo
« Reply #34 on: 05 July 2012, 21:42 »
No props mate, Il have a little look.
If you pm me a price delivered il let you know.
Im a welshman im cheeky and wouldnt want to offend haha
« Last Edit: 06 July 2012, 09:02 by jamie1989 »
Offline rio_gti
Re: ko3 turbo
« Reply #35 on: 05 July 2012, 23:07 »
dalo harkin with you having the small port head why dont you put the s3 inlet manifold on yours with the throttle body on the passanger side and get a s3 or lcr FMIC from toyo sports as there alot easier to fit. will work out cheaper than the THS FMIC.
See I was thinkin about puttin different inlet manifold on but still has the small ports on the actual block do figured it would be a waste  :undecided:
Offline DunnDeal12
  • Limited
Re: ko3 turbo
« Reply #36 on: 05 July 2012, 23:29 »
its a cheaper option on the small port as the forge/THS intercoolers cost alot of £££. the inter cooler comes to about £200, LCR/S3/TT inlet manifold £50, LCR/S3/TT charge pipe £40.
Offline Dalo Harkin
Re: ko3 turbo
« Reply #37 on: 06 July 2012, 08:49 »
sounds like a plan but for all the messing I would rather just get the S3 injectors not wrong about the THS cooler though £500 and its not even here yet  :sick:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: ko3 turbo
« Reply #38 on: 06 July 2012, 15:49 »
Calibra yellows will be the wrong impedance for your ECU too
