Author Topic: Fitting Catch Can  (Read 14278 times)
Offline harlemex
Re: Fitting Catch Can
« Reply #70 on: 04 July 2012, 16:19 »
the coloured silicone can be quite expensive if you want it oil fuel specific i just used normal silicone hose as the ones on my car were near enough 14 year old so figured its gotta be better if it perishes in a few years then il just replace chances are the hose will probably outlast the car now  :grin:
oil fuel specific
http://www.ebay.co.uk/itm/Blue-Silicone-Hose-Fuel-Oil-1-Metre-19mm-/330578233299?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cf7ff87d3
standard silicone
http://www.ebay.co.uk/itm/1-Metre-Silicone-Straight-Long-Hose-Silicon-Rubber-Coolant-Radiator-Pipe-Water-/330651132313?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item4cfc57e199
hmmmmmmmmmmmmm £17.71 per metre as opposed to £7.61, i know which 1 il be gettin  :laugh:
+1 I bet the cheaper stuff will be fine.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #71 on: 05 July 2012, 16:14 »
It will soak up the oil vapour and the pipe will eventually collapse or split. The hoses you are replacing aren't flouro lined either which is why they split
Offline andc1
« Reply #72 on: 05 July 2012, 18:23 »
Bin the hockey puck , you don't need it  :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #73 on: 05 July 2012, 18:30 »
some would beg to differ with that, but I don't run one and have never had any problems
Offline DubAndDubber
« Reply #74 on: 05 July 2012, 19:45 »
The best arguement against that is, why would vw put it there of its not needed?!
Mk5 Golf Gti 06'
Offline Dalo Harkin
« Reply #75 on: 05 July 2012, 19:52 »
Isnt it just a one way valve like all the others that get removed  :smiley:
Offline DunnDeal12
  • Limited
« Reply #76 on: 05 July 2012, 20:24 »
i think its something do with emissions or the environment
Offline jamie1989
« Reply #77 on: 05 July 2012, 20:29 »
I dont run one either and report with no problems!  :cool:
Best thing I did was bin the whole pvc system to be honest.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline lemski
  • 16v
« Reply #78 on: 05 July 2012, 21:16 »
I've just fitted my catch can today. Plus binned of the hockey puck. My tip came with it pre-blocked so I left it this way
Offline lemski
  • 16v
« Reply #79 on: 07 July 2012, 12:29 »
Catch can still goes into tip.  Just by a breather that was blocked off. So I binned the hockey puck. Seamed like an unnecessary thing to have.
