Author Topic: Gt sport 170 tdi not starting  (Read 2966 times)
Offline stevieC
« on: 02 July 2012, 20:41 »
As topic say's the car turns over but won't start,this has been happening over the last few weeks & maybe not started about 6 times.car will start first turn in the morning then when u go back to start it just turns over,sounds as if no fuel is getting through.Also had the injector recall a few weeks ago this is probably when it all started.anyone else had this problem.
Gtd 3dr candy white,charleston shadows
Offline Rhyso
Re: Gt sport 170 tdi not starting
« Reply #1 on: 02 July 2012, 20:51 »
Does it only fail to start if the car is up to temperature?  i.e. you drive it for a few minutes or more then stop then try to start?
Offline stevieC
« Reply #2 on: 02 July 2012, 20:58 »
Yeh rhyso but just drove a 200 mile round trip on sat with no probs,but your right it will only happen after you've started it drove then tried 2 start it again.
Offline Rhyso
« Reply #3 on: 02 July 2012, 21:25 »
I know a bloke with a Passat who had a similar problem; had to wait for the car to cool down
Think it was the cam position sensor that was at fault  :undecided:
Offline stevieC
« Reply #4 on: 02 July 2012, 21:29 »
Cheers for that.got it booked into vw on wens 2 see what they say.
Offline stevieC
« Reply #5 on: 06 July 2012, 20:32 »
Rhyso u were right cam position sensor,vw want £540 to fix.Is this fault comming up due to the timing belt just being changed.
Offline Rhyso
« Reply #6 on: 06 July 2012, 20:42 »
How much??!! Bloke with the passat paid less than £100 to have his sorted  :undecided:  he certainly didnt pay that!!!  VW wanted to change is ecu mind at £800.....
Offline stevieC
« Reply #7 on: 06 July 2012, 21:06 »
Vw say,diagnostic, 4 hrs fitting part & part £540 do they need to remove timing belt.
Offline Rhyso
« Reply #8 on: 06 July 2012, 21:43 »
Hmm drop Topher a PM; he works for Midland VW and can confirm if thats true  :smiley:
Offline Organisys
  • Old and Slow...
« Reply #9 on: 06 July 2012, 21:58 »
Find an independent who can correctly read any fault codes.
