Author Topic: 42 Draft Stealth catch can  (Read 2480 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 28 June 2012, 12:42 »
This may sound like a stupid question, but I just received my 42 Draft Stealth catch can, and was wondering how do I drain the oil out in the bottom? do I have to use an allen key to undo it! Or does anyone know where I can get a Oil Catch Can Quick Drain Tap Fitting in the U.K.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Dalo Harkin
Re: 42 Draft Stealth catch can
« Reply #1 on: 30 June 2012, 08:09 »
Afaik you will only have to empty itevery 12m or so, so just allen key it
« Reply #2 on: 30 June 2012, 19:45 »
12 months or so, is much better than I thought! I have found a tap that is specifiically for it from Australia, so I think I will order one next week
« Reply #3 on: 30 June 2012, 20:05 »
Does this set up look right to you catch can folks? does it matter that there is a small kink in the pipe going to the rocker cover?
Offline Chris.
« Reply #4 on: 30 June 2012, 20:07 »
Looks fine to me!
Click For Build Thread
« Reply #5 on: 01 July 2012, 10:28 »
Looks fine to me!
Great, thanks. So the kink doesn't really matter? I was thinking of puting in a 90' joiner to get rid of the kink.
