Author Topic: Golf 1.8t flat spot/holding back  (Read 1925 times)
Offline gti_boz
« on: 27 June 2012, 20:09 »
My golf has started to hold back when boosting.. It's Asif it wants to go but somthing is holding it back, then when you get over a certain revs it seems ok.. Any ideas?
N75 valve?
Boost leak?
What do you recon?
Cheers :)
Offline cullygti
Re: Golf 1.8t flat spot/holding back
« Reply #1 on: 27 June 2012, 20:10 »
id go for boost leak give it a good check over if it aint a leak then try the n75  :wink:
Offline richw911
« Reply #2 on: 27 June 2012, 20:11 »
Any fault codes?
Offline gti_boz
« Reply #3 on: 27 June 2012, 20:12 »
No codes mate plugged it in earlier
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #4 on: 28 June 2012, 10:43 »
check that pcv pipe work, I just found another split on my aum in the pipe that connects to the suction jet pump under the manifold. So I am now waiting for my catch can to arrive from Awesome GTI.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
