Author Topic: ignition switch? shear bolt?  (Read 2167 times)
Offline nhop10
  • Mk3 GTi
« on: 26 June 2012, 17:03 »
i have a few electrical issues. which have been talked about in a previous post of mine. i have been told that it could possibly be solved by buying and fitting a new ignition switch. after buying one and then reading the haynes manual to see how to fit it it says about fitting a new shear bolt in the steering column. i gather this is designed to only be fitted once? where can i get one of these bolts? anyone replaced their igniton switch?
cheers
Mk1 Golf 1.1, 6n Polo 16v, and now an 8v mk3 GTi
Offline Screech16v
  • MK3 20vt AGU
Re: ignition switch? shear bolt?
« Reply #2 on: 26 June 2012, 20:55 »
Or if you carefull you can remove the old one with a pair of mole grips.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #3 on: 26 June 2012, 22:14 »
as above, piss easy
replace with a normal bolt
or you can buy the sheer type at the dealers for a pence..
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 26 June 2012, 22:16 »
My shear bolt was finger tight  :shocked:
Offline nhop10
  • Mk3 GTi
« Reply #5 on: 26 June 2012, 22:22 »
cheers fellas. i might be more tempted to just follow the haynes manual and try with the mole grips. but will have another read through and see how much more complicated it is. or if i can get another bolt i might try that. i take it theres no part number for something like that?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 26 June 2012, 23:43 »
When I was fitting my heated seat loom I noticed mine was literally half way unthreaded and very loose. Obviously as it had no hex head on it to tighten I simply swapped it with another normal bolt so I could do it up properly which instantly resolved my wobbly column.
This said I'm not sure whether it'll still do its job in a crash as its more than likely the wrong grade steel.
