Author Topic: radiators  (Read 2125 times)
Offline kempie
  • where would we be without duct tape?
radiators
« on: 26 June 2012, 14:36 »
hey guys i have a 1.6 AAE and i think the radiator is on its last legs,
the question is if i get a double fan set up and all that jazz, am i going to have problems or is it going to be plug and play ??
thanks
Offline Khare
  • The bear that khares
Re: radiators
« Reply #1 on: 26 June 2012, 17:06 »
Why go through all the hassle of buying a more expensive setup if it's going to be of no benefit?
The system it currently has is more than enough to cool it. You could look at possibly a 16v/vr6 radiator which has more cores. Not sure if the bolt holes are the same though.
Gavv8
Re: radiators
« Reply #2 on: 26 June 2012, 20:22 »
Would you not then run the risk of overcooling and the resultant increase in fuel consumption?
Offline Khare
Re: radiators
« Reply #3 on: 26 June 2012, 20:37 »
No because the thermostat will control it.
Gavv8
Re: radiators
« Reply #4 on: 26 June 2012, 20:45 »
Fair enough but i think it would be better to fit the correct replacement for the car.
Re: radiators
« Reply #5 on: 26 June 2012, 20:51 »
Agreed, it does not need the extra cooling
Offline kempie
Re: radiators
« Reply #6 on: 27 June 2012, 17:52 »
thanks guys i honistly dont have a clue on cooling thats why i asked and again thanks :)
