Golf mk3
hardmonkeys
Will a standard 1.6 exhaust fit a 1.8?
Topic: Will a standard 1.6 exhaust fit a 1.8? (Read 1528 times)
Jasikasisback
25 June 2012, 12:17 »
Hii am trying to find a reqsonably priced exhaust for my 1.8 aam eutomatic golf. I was wondering if there is any difference between the 1.6 exhausts to the 1.8 and if they are compatible. They look very similar but the part numbers are different.
Just wondering.
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Re: Will a standard 1.6 exhaust fit a 1.8?
25 June 2012, 19:19 »
1.6 uses a smaller bore.... but can be made to fit (full system) from the cat back with a connector/reducer piece
Jasikasisback
26 June 2012, 04:12 »
Is that safe or will it cause difficulties for the engine, ecu etc,,,,
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
26 June 2012, 11:19 »
Why buy a 1.6 exhaust? If you want a cheap exhaust go on ebay and buy one that fits....
And which 1.6 / 1.8 are we talking about?
If you take 75PS versions of 1.6 and 1.8 the mid- and end silcencer are the same. 1.6 100PS uses the same bore as 2.0 115PS (at least on the estate).
ECU won't know which one you have connected... as long as you're not trying to fit one from a less powerful engine (i.e. smaller bore) you're OK
Jasikasisback
26 June 2012, 16:20 »
I am trying to find acheap one but not having much luck on ebay. Maybe just dont know where to look!
itavaltalainen
26 June 2012, 16:31 »
which one do you need? midbox or end, or both?
what is "cheap" for you?
I found some for 60£ for both of them together on ebay? But suspect they are cheapest sh!t, fairly decent system should be around 100£.
Not really a lot of money...
Golf mk3
hardmonkeys
