Author Topic: 8v doesn't turn over.  (Read 4349 times)
Offline JimR
Re: 8v doesn't turn over.
« Reply #10 on: 27 June 2012, 18:28 »
Yeah, sorry, that was the knock sensor. The earth look fine, I get continuity from one end to the other on the multimeter, I'm starting to suspect it may be the ignition switch but I do get 12v at the starter motor trigger wire when I turn the key. At a bit of a loose end at the moment.
Mk2 GTi.
Offline weazgti
« Reply #11 on: 27 June 2012, 19:06 »
I just got a mk3 starter motor for 25 quid and banged that on mine. Works a treat.
Offline JimR
« Reply #12 on: 27 June 2012, 19:09 »
Scrub that, just earthed starter motor body to the battery and it shifted into life so guess it's an earth problem, cheers guys.
Mk2 GTi.
Offline Mr Blue
« Reply #13 on: 27 June 2012, 21:08 »
Good stuff James. If you need a hand then give me a shout  :smiley:
Offline JimR
« Reply #14 on: 27 June 2012, 21:22 »
Cheers mate, if I see you tinkering with your car I'll stop and say hello.
Mk2 GTi.
Offline Mr Blue
« Reply #15 on: 27 June 2012, 21:37 »
No problem. Always tinkering with a motor  :smiley:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #16 on: 27 June 2012, 22:20 »
 :wink:
