Author Topic: Rear hubcentric wheel spacers don't fit  (Read 16524 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Rear hubcentric wheel spacers don't fit
« Reply #30 on: 11 December 2012, 23:53 »
Yep,  ive decided il be making some spacer plates at work instead.  Il be able to keep my locking wheel bolts as well as having no faffing around with chamfers and longer wheel bolts etc.
http://www.golfgtiforum.co.uk/index.php?topic=163410.330
VW BUSH
« Reply #31 on: 12 December 2012, 18:16 »
Id stay away from Aluminium and use BMS or P20
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #32 on: 12 December 2012, 19:08 »
BMS will rust and P20 is tool steel, which is pre-hardened and wont exactly be that easy to machine and drill, I would use some 304 stainless, pretty cheap, easy to machine and doesn't rust.
Aluminium would be ok for this application as theres no real stress on the spacer plate itself once everything is all bolted up together, my first choice would still be the stainless tho  :wink:
« Reply #33 on: 12 December 2012, 19:34 »
I cant see how using aluminium could be an issue when you consider that virtually all the off the shelf wheel spacers are made from machined solid blocks of aluminium.
Offline tweed
« Reply #34 on: 12 December 2012, 19:57 »
I was thinking the same thing  :huh: I've got a bit of blue plastic and that's ok.
