Author Topic: weird backwards pumping  (Read 2137 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: weird backwards pumping
« Reply #10 on: 22 June 2012, 19:12 »
It creates a black hole every time.
Offline willz94
« Reply #11 on: 22 June 2012, 23:23 »
lmao black hole  :grin:
Because its bubbling with air going into it?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #12 on: 23 June 2012, 11:24 »
How odd...  Now correct me if im wrong as i havnt taken a golf pump off the bottle for years, but doesnt the pump flip polarity to the rear screen,  there is only one pump, so you run it forwards to the front screen and backwards to supply the rear screen.  So somewhere along the line, the boot vac pump is leaking current into the circuit between the rear washer switch, relay, fuseboard and the pump its self.   I would expect using the rear washer switch would then activate the vac pump if thats the case?   I probe it and see how many volts there is, if you get a good 12v on the rear washer switch, but less when it does it by its self, i would suspect there is a short in a wire somewhere.... Sometimes all it takes is bad ground point somwhere to send everything crazy.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline willz94
« Reply #13 on: 23 June 2012, 12:27 »
shall check this out when im down the garage next and let you know :) thanks for the helpful input!
