Author Topic: really bad day. bloooody wheel bearing  (Read 4702 times)
Offline mrsaunders
Re: really bad day. bloooody wheel bearing
« Reply #20 on: 22 June 2012, 09:15 »
Doin mine soon so these tips will help me out abit  :smiley:
Offline stainesy
« Reply #21 on: 22 June 2012, 09:25 »
Ok another update. Just took it for a good drive round the block a few time round some twisty corners. Took it back to my garage jacked it up and had another check and all seems ok. If I grab the wheel top and bottom and give it a good tug each way there is like a nano mm of play you can barely feel and if I grab the wheel on each side there is the tiniest amount of play not even enough to notice just a slight tic feeling if that makes sence. So seems good.
although on the downside i must have forgot to pop my vw centre cap back in propply and lost it wile taking it for a drive  :angry:
but hay fcuk it atleast i can drive my car again. woohoo. great advice peeps  :wink:
« Last Edit: 22 June 2012, 09:39 by stainesy »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #22 on: 22 June 2012, 09:42 »
I would imagine the grinding noise was infact the ABS ring rubbing against the sensor if the bearing had that much slack in it. I had a similar issue on mine earlier this year, might be worth checking it for damage.
Offline stainesy
« Reply #23 on: 22 June 2012, 09:45 »
had a good look today and found that the grinding was the metal inside the wrong larger seal between the rear of the hub and the bit at the back of the stub axle as it was not pushed in flush to the hub. cheers for the advice though fella.
« Reply #24 on: 22 June 2012, 09:47 »
Ok cool, that was lucky then.
Offline stainesy
« Reply #25 on: 22 June 2012, 09:53 »
yeah i somehow managed to dodge a bullet on this one   :smug: :grin:
Gavv8
« Reply #26 on: 22 June 2012, 21:26 »
Turned out nice again.. :smiley:
Offline Bandit127
« Reply #27 on: 22 June 2012, 21:30 »
+1
Offline stainesy
« Reply #28 on: 22 June 2012, 22:51 »
Oh yes   :cool:
Thank fcuk  :grin:
Offline mrsaunders
« Reply #29 on: 05 July 2012, 16:18 »
what tools do i need, having a bash saturday
