Author Topic: Golf mk3 1.4 owners need advice.  (Read 5879 times)
Offline Khare
  • The bear that khares
Re: Golf mk3 1.4 owners need advice.
« Reply #10 on: 22 June 2012, 17:13 »
By the way, no sure whether the 1.4 has a middle silencer or not, but if it does then a backbox won't do much in terms on noise, as it's the much larger middle silencer that quieten it the most. I ran a backbox on mine when I first got it and it made pretty much no difference at all, not until I removed the middle silencer.
Offline search
« Reply #11 on: 22 June 2012, 17:30 »
actually though as much, thanks. so what do i use to replace the mid section.
as to other fella about S pipe pretty sure it can be cut off at the box section then put this one in its place no?
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline chrisford_vw
« Reply #12 on: 22 June 2012, 17:47 »
Could cut it but would be a pain if you wanna put the standard backbox back on.
The s pipe I put deletes the middle box too  :wink:
Offline murraymint
« Reply #13 on: 22 June 2012, 17:49 »
I've done this on my backbox on my 1.6 but it had to Be welded together
josh
Offline search
« Reply #14 on: 22 June 2012, 18:01 »
original back box are only like £40 thats with the S pipe on anyways. thanks for the tip about the other s pipe tho. also is thats whats known as De-cat? sorry noob ere lol. if i did replace the mid section will it pass MOT emissions ok?
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline search
« Reply #15 on: 22 June 2012, 18:03 »
Thanks same back box as one in Question? as the one in question should come with a clamp and same size as standard so i actually hoping if it does have to be welded then it be a cheap job as they wont need to make up pipes to extend it ETC.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline murraymint
« Reply #16 on: 22 June 2012, 18:05 »
Na my one was off my mates 1.4 mk3, Ive only got it as it was free and my old backbox had snapped off. It was welded on his car so we had to cut it off n reweld it to mine
josh
Offline Khare
Offline 67buggers
« Reply #18 on: 22 June 2012, 18:07 »
this is what mine looks like...
This is who supplied and fitted it for £180
And this is what they supplied .... Hope it makes sense!....sorry the last pic is upside down
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline search
« Reply #19 on: 22 June 2012, 18:10 »
AH Got you now. so i should buy that mid section replacement for a better sound.
did see this wasn't sure tho... THANKS GUYS MUCH APPRECIATED  :smiley:
http://www.ebay.co.uk/itm/CHERRY-BOMB-3-EXHAUST-CB3-2-REDUCER-STEPPED-IN-O-/270725197398?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f087aae56#ht_526wt_698
« Last Edit: 22 June 2012, 18:14 by search »
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
