Author Topic: thread of the week  (Read 28221 times)
Offline Bandit127
Re: thread of the week
« Reply #20 on: 18 June 2012, 22:08 »
Why not  :evil: if i cut my arb out to get my golf slammed would i then be able to use it as a washing line ?  :undecided:
You can only do that if you fit a K04 turbo. The K03 and K03s don't have the spool torque needed to keep the line tight. Then get it mapped and you will be fine...
Ordnance Survey do the best IMO...
« Last Edit: 18 June 2012, 22:10 by Bandit127 »
Offline AD1.8T
« Reply #21 on: 18 June 2012, 22:18 »
Would filling up my rear window with stickers help at all ? Obviously i would include a "ko4 inside" sticker !!
Offline Tezmax
« Reply #22 on: 18 June 2012, 22:33 »
Not really as the power to weight ratio will be effected dramaticly and in due course would reduce the life expectancy of ur ARb
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline dom
  • Back in a Mk4
« Reply #23 on: 18 June 2012, 22:35 »
You need to remove the left felanji to counter balance that weight gain :wink:
Offline richw911
« Reply #24 on: 18 June 2012, 22:42 »
How do I post pictures?
Offline JimBR
« Reply #25 on: 18 June 2012, 23:04 »
 :grin: I love how there is more and more banter on here  :smiley:
Offline cullygti
« Reply #26 on: 19 June 2012, 00:05 »
to post pictures you need to get them developed pop them into an envelope write down the address  put on a stamp and pop the envelope into a big red box called a post box where some guy will then deliver them for you.... i dont know the address so ask someone else
Offline richw911
« Reply #27 on: 19 June 2012, 08:32 »
Thanks for the help now  :cool:
Will my ARB rub if I fit lorry wheels and drop it 967mm?  :undecided:
Offline cullygti
« Reply #28 on: 19 June 2012, 09:35 »
you should be fine if it were 968mm the the tyres would rub on the door but 967 should be ok  :laugh:
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
« Reply #29 on: 19 June 2012, 09:40 »
As long as you've got 6.782mm spacers, go for it!  :wink:
Mk4 Gti - Gone but not forgotten!
