Author Topic: Lumpy acceleration 1.8t  (Read 8153 times)
Offline gjroe78
Re: Lumpy acceleration 1.8t
« Reply #30 on: 04 July 2012, 19:47 »
Is it safe to drive it without the MAF on to test it ?
Not got VagCom either  :sad:
Offline daz veedub
  • Operation 1.8t bolf
« Reply #31 on: 04 July 2012, 21:20 »
yes but only like a quick test down the road sort of thing really
Offline gjroe78
« Reply #32 on: 05 July 2012, 11:40 »
This could be a ridiculous question but are mafs different in different model golfs ? I guess they have to be don't they  :undecided:
Offline richw911
« Reply #33 on: 05 July 2012, 22:46 »
Yes
Offline gjroe78
« Reply #34 on: 06 July 2012, 19:41 »
Short and sweet answer to a dumb question  :grin:
Offline xxChrisxx
« Reply #35 on: 06 July 2012, 19:59 »
First thing to do is check the sparkplugs. They will give an indication as to whats going on in the cylinder.
If it's been doing it a while, that plug is likely going to be shagged.
Offline gjroe78
« Reply #36 on: 08 July 2012, 10:20 »
Right, I bought a 2nd hand maf of eBay(that I have been assured works) fitted it this morning and still the problem exists !!!
Someone else has suggested the spark plugs would this cause the stuttering under acceleration ?
Oh I no longer have any fault codes after resetting and giving it a run.
Offline JimBR
« Reply #37 on: 08 July 2012, 10:37 »
Id say they sold you a dodgy MAF.
But also take the plate infront of the inlet manifold off and check all the breather hoses for splits. Also check all the smaller vacuum lines. I would say these have got a good chance of contributing to your problem.
Offline xxChrisxx
« Reply #38 on: 08 July 2012, 10:47 »
A car only needs 3 things to work.
Correct quantity of air.
Correct quantity of fuel.
Spark at the right time.
If one of these is missing, you'll get poor combustion.
It's also easier to start closest to the cylinder and then work backwards.
Even if the spark plug isn't the problem, it will give an indication to the problem by what it looks like.
Offline gjroe78
« Reply #39 on: 08 July 2012, 10:55 »
I've just emailed the place I bought the maf from and asked them why they were so sure it worked ?
I'm gonna have to check the pipes and plugs later as I'm off out in a bit so not gonna have chance to do owt.
Getting really pissed off with this now, just want to get it sorted  :angry:
