Author Topic: 1.6 turbo?  (Read 6579 times)
Offline DunnDeal12
  • Limited
Re: 1.6 turbo?
« Reply #10 on: 15 June 2012, 09:24 »
No 1.8t came with forged rods or pistons... what you have heard is incorrect.
The majority of internal water pump 1.8t have forged crankshaft if that's what you mean...
A lot of misinformed things have been mentioned but the important thing is if an engine conversion is to be done it is best to start with the throttle body - is your car drive by wire or cable? But is out of the scope of this thread.
I agree with the sentiments of other members; it's cheaper and much less headache to just buy a 1.8t gti and stick a few bolt on mods then map it as opposed to paying someone to source and do the engine conversion on your behalf.
ah ok... but is the agu internals stronger than aum auq and same as bam? or they all identical?
o yea and agu is drive by cable... much begter imo :P
think there all the same except i dont think the aum, auq etc run a forged crank.
Offline rockmonkey69
Re: 1.6 turbo?
« Reply #11 on: 15 June 2012, 11:44 »
Aum and auq run a forged crankshaft, yes agu has slightly stronger standard rods compared to aum. Which is all pointless given that they all will more or less handle 300 ft-lb of torque for arguement sake, but if you wanted more on either engine you would ideally upgrade the rods anyway...
The cable throttle is a benefit but so too is the me7 ecu fitted on later cars when it comes to mapping.
Bam also has forged crankshaft but the piston is different from agu or aum or auq for that matter, bam pistons are lower in compression although it retains the same stroke and bore size.
As I had said before, whenever I do an engine conversion I always source the same type of throttle engine as what the car had originally. So if a car came with drive by wire, then fit an aum, auq, bam, if it came with drive by cable then stick to an agu, I would not bother changing between the two and chances are most people would not be willing to pay me extra to change between it anyway...
nath20vt
Re: 1.6 turbo?
« Reply #12 on: 15 June 2012, 15:47 »
iv just done a aum conversion to my 1999 mk4 golf from a 1.6 and tbh id never do another one more hassle than its worth only reason i done it was because i got the car so cheap id deffo just go out and buy one next time
Re: 1.6 turbo?
« Reply #13 on: 15 June 2012, 15:56 »
You can pick a running 1.8t a3 or golf up so cheap now, my mate just bought a running 02 reg golf 1.8t for £900 with the turbo seal going a little. Bough a k03s for well under £200 and fitted it. All running fine now. It's simply not worth it anymore. We have to remember the mk4 is over 10 years old now.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 1.6 turbo?
« Reply #14 on: 15 June 2012, 16:42 »
AGU has bigger wrist/gudgeon pins, that is all  :wink:
Offline Dalo Harkin
Re: 1.6 turbo?
« Reply #15 on: 15 June 2012, 18:08 »
ring your insurance company first and tell them you are converting to a 1.8T engine and see the price  :sick:
then get a quote on a car that is a 1.8T  :smiley:
modifying and engine transplants especially up your insurance
Offline golf-sib
  • Турботазик
Re: 1.6 turbo?
« Reply #16 on: 15 June 2012, 23:23 »
AGU had 20mm pins, which is a good number over the aum's 19mm. Popular thing is to use the 2.0TFSI forged crank, then you end up with a stroker setup with a 2.0t 20v engine. There's loads you can do with the 1.8T engines depending what power you want, as exhuast valves give up around 350bhp, so you may as well upgrade the entire valvetrain if you aim to go beyond that especially if you want to raise the limter. Then with all that power there's issues with the driveshafts, then gearbox at high end power... it's all fun and games. Then you have rod's and people up the pistons as well... but I won't bore you.
Best bet is just go and get a 1.8t golf to begin with than nonse around with a conversion especially with the price of these now.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline 1.6mk4GOLF16v
Re: 1.6 turbo?
« Reply #17 on: 16 June 2012, 19:11 »
cheers for the replies guys
rockmonkey what have you done to that 1.6 in ur pic? looks very interesting  :smiley:
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline golf-sib
  • Турботазик
Re: 1.6 turbo?
« Reply #18 on: 16 June 2012, 19:17 »
Thats a 1.8T
1.8T AGU..
R135
  24
Re: 1.6 turbo?
« Reply #19 on: 17 June 2012, 11:45 »
Removed the 1.6 and put in a 1.8t, stripped the 1.8t down and completely rebuilt it with forged internals and all new components, i.e new tappets, oil pump and pickup etc etc. ported, port matched and valve work. Being run in on stage 2 at the moment.
« Last Edit: 17 June 2012, 11:49 by rockmonkey69 »
