Author Topic: mk3 gti no spark after changing engine  (Read 4315 times)
Offline royster831
Re: mk3 gti no spark after changing engine
« Reply #10 on: 13 June 2012, 20:26 »
Some have used vag com or vag tacho I just went a got a ecu immo box and key for the chip it worked out cheaper:
Reply i got when i asked:
First I would find someone with vag-tacho to see if they can read the SKC from your immo box. As without this SKC recoding can't be done easily. If they can then just buy an ecu and recode with vag-com. Some mk3's won't let you read the SKC with vag-tacho and require some more specialist tools and I don't know many people who offer this service.
Another option is replace the ecu with one with the immobiliser defeated.
ok cheers my frend ...let you know wat occurs ..might just sell its had enough cash out of me and only done 20 miles last year
Offline Stewy12
« Reply #11 on: 13 June 2012, 20:36 »
I got a mate who is breaking a couple of mk3s i could try and nab the lot if u need it ??
Offline Stewy12
« Reply #12 on: 14 June 2012, 17:44 »
Here is the layout for the relays and fuses/wiring to fuse box i said about in phone call  http://www.a2resource.com/electrical/CE2.html let us know what happens when you put in relay 3 (30 or 32)
Offline mark-mk3gti
« Reply #13 on: 14 June 2012, 22:44 »
It's not hard to do with vagcom, aslong as u have a matching key to immob box, if u don't it does get tricky recovering skc code.
Anyone near by with vagcom? To help him out? :)
Offline Stewy12
« Reply #14 on: 14 June 2012, 22:51 »
After talking with him today there is a lot more to it than just immo i think going from a 1.6 to 2.0 certain things were missing ie relays and thinks so on and so on
