Author Topic: W.M.I activation light  (Read 1768 times)
Offline Chris#101
« on: 12 June 2012, 12:44 »
Howdo, I swear Ive read on here a few people that have wmi that have also installed an led that comes on when the wmi is activated via boost. My problem is, is that I cant find the bloody topic :smiley:
So would anyone be kind enough to guide me on how to wire up an led so it comes on when the pump activates?
Sorry electrics arent my strong point  :lipsrsealed:
many thanks  :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline DunnDeal12
  • Limited
Re: W.M.I activation light
« Reply #1 on: 12 June 2012, 14:09 »
id also like to no this as ive just picked up a WMI kit up for mega cheap.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 12 June 2012, 17:27 »
if the controller sends a +ve signal to the pump it's easy enough to do, you'd just have to install an LED in line on that cable and mount it somewhere  :smiley:
My controller has a few LEDs on it anyways
Offline Chris#101
« Reply #3 on: 12 June 2012, 17:38 »
I went for the poor man option which is the manual adjusted boost control solenoid :( but I guess even that must have a +ve signal to operate the pump!?  :smiley:
« Last Edit: 12 June 2012, 17:41 by Chris#101 »
Offline DunnDeal12
  • Limited
« Reply #4 on: 12 June 2012, 17:50 »
have any of you got any pics where you mounted the nozzle as im tempted to make a throttle body spacer with a WMI dual port.
Offline Chris.
« Reply #5 on: 12 June 2012, 18:20 »
Use the vacuum one on the top of throttle body?  RIP the stupid charcoal canister out and use that nipple ;)
Click For Build Thread
Offline DunnDeal12
  • Limited
« Reply #6 on: 12 June 2012, 18:37 »
just deleted my charcoal canister (easy enough) but does that 90 degree nipple on top of the throttle body can that be screwed out or does it have to be chopped off and re-tapped?
Offline Chris.
« Reply #7 on: 12 June 2012, 18:37 »
Screws out I think
Offline Toby
  • Car - less
« Reply #8 on: 12 June 2012, 18:56 »
i want WMI!  :cool:
Currently down under
Offline wasps1990
  • Per Mare, Per Terram
« Reply #9 on: 12 June 2012, 19:00 »
i mite sound thick lol but whats WMI lol sorry lads
