Author Topic: Sunroof motor  (Read 2546 times)
Offline robo22sri
Re: Sunroof motor
« Reply #10 on: 18 June 2012, 19:35 »
no one know how to set up the sunroof?
Offline robo22sri
Re: Sunroof motor
« Reply #11 on: 20 June 2012, 20:46 »
No one got any help on setting up a sunroof them??
Offline stainesy
Re: Sunroof motor
« Reply #12 on: 20 June 2012, 21:05 »
have you checked that both metal slide runner things move both ways?
my sunroof opens but then dont close as one of mine is broken on one side and only goes one way. so i need a new sunroof.
iv just wound mine into position with allen key and put and coupe of screws in the broken side to hold it closed. and its now just a sky light. :grin:
Offline robo22sri
Re: Sunroof motor
« Reply #13 on: 20 June 2012, 21:07 »
I will double check that tomorrow
Offline stainesy
Re: Sunroof motor
« Reply #14 on: 20 June 2012, 21:14 »
yeah i cant remember what the bits are called but if you look at the sides from inside the car under the plastic thing you will see a silver metal thing. thats the bit that the motor moves back and forth that opens and closes the sunroof. you can see if they both work by making the sunroof slide back they when you try to close it again only one will move back again and the sunroof with jam. then you have to wind it back with allen key.
if only one moves back then the other side is broken and you need a new sunroof.
Offline robo22sri
Re: Sunroof motor
« Reply #15 on: 20 June 2012, 21:19 »
Just checked that and its ok, both sides are good :)
Offline robo22sri
Re: Sunroof motor
« Reply #16 on: 08 August 2012, 21:53 »
Bump my old thread!
How do you get the sunroof to function properly?
My sunroof only goes back wards! it wont come forward!
Offline Dogbot
Re: Sunroof motor
« Reply #17 on: 15 August 2012, 12:35 »
Rob how you fix it is....... you come round an get mine that works an is sat a mile away from yours  :smug: :drool: :drool: :grin: :grin:
Offline robo22sri
Re: Sunroof motor
« Reply #18 on: 16 August 2012, 08:21 »
lol Are you about this weekend?
Offline Dogbot
Re: Sunroof motor
« Reply #19 on: 16 August 2012, 10:56 »
Yes Sweetheart I am, I will be heading to the workshop in billericay around 10 ish.... be at home before that if it helps
