Author Topic: Prospero seriously ill!  (Read 19909 times)
Offline Snoopy
  • Moderator
  • Geoff.
Re: Prospero seriously ill!
« Reply #50 on: 18 June 2012, 18:32 »
If it was just a belt jumping teeth seems odd full new engine.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Rolfe
« Reply #51 on: 19 June 2012, 00:07 »
Pass.  I literally have no clue.  Andrew, who has maintained the car from new, is quite frustrated.
He agreed it could have been the timer belt ("though it's way too young to expect that to fail"), and then the aggressive attempts to start it did the major damage.  But we're all just guessing.
Offline Edi35
« Reply #52 on: 19 June 2012, 13:41 »
Once the belt has slipped, valves and pistons will be out of timing and will meet in a major metal mashing. This could damage all the major parts of the engine.
Current: GTI Edition 35 Candy White 5dr DSG 19" Glendale, RCD510+DAB, Dynaudio, Storage Pack, Parking Sensors
Gone: Edition 35, GTI Mk6, Edition 30, GTI Mk4, GTI Mk3, GTI Mk2 and my favourite the UR quattro
For those that dont know DSG is an electronically controlled dual-clutch multiple-shaft manual gearbox
Offline Egbutt Wash
« Reply #53 on: 19 June 2012, 17:27 »
The tension in the timing chain relies on a big banana shaped block pushing against the chain.  It gets its push from oil pressure.  If your oil is knackered (and oil does go off in an alarming way) it might cause this failure.
Currently digging a bunker.
Offline Rolfe
« Reply #54 on: 19 June 2012, 17:53 »
It's not a chain in this particular car, it's a belt.  And this car was serviced only three weeks before the incident.
Offline p3asa
« Reply #55 on: 19 June 2012, 18:00 »
Are you sure Rolfe? I thought the GTI was a chain and the R was a belt!
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #56 on: 19 June 2012, 18:14 »
The Mk6 Gti uses a timing chain.  This is kept nice and tight by a hydraulic tensioner, running off engine oil pressure.  When the engine is stopped the oil pressure drops to zero and some oil in the tensioner can leak past it's stop valve, leading to a more sloppy timing chain.  This is when the chain can skip.  Constant turning over of the engine in this state can cause more skipping and in the end allow the valves to open onto the top of the piston, which is no good.
You often hear the sloppy timing chain on start up on all VW's TSI engines.
does turning it over not increase the oil pressure? As that's what your suppose to do to old cars when they stand for a ages unused.
Mk6 GTI  &  Mk1 GTI
Offline Edi35
« Reply #57 on: 19 June 2012, 19:08 »
+1 GTI has chain (EA888) and R/ED's have belts (EA113) I think that's right.
Offline mike.
« Reply #58 on: 19 June 2012, 20:08 »
Hardly complicated at all, how could it possibly go wrong  :shocked: :shocked:
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #59 on: 19 June 2012, 20:49 »
Am I right in thinking that we know of 3 tensioners that have failed.
Were the cars all built same period?
Mk6 GTI  &  Mk1 GTI
