Author Topic: Map sensor on inlet manifold  (Read 1366 times)
Offline Lewis1.8t
« on: 11 June 2012, 20:53 »
Hi all I need to no if it's ok to mount the map sensor on my mates aum 1.8t on the inlet manifol. Just need to no if it's will be ok post throttle body and will work just the same? Cheers in advance for any help.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Map sensor on inlet manifold
« Reply #1 on: 11 June 2012, 21:06 »
why would you want to do that?  :huh:
Offline Lewis1.8t
« Reply #2 on: 11 June 2012, 21:11 »
Because he has fitted an eBay front mount and they don't has a hole for them, and he don't want to buy the forge map splice in pipe if we can get away with putting it on the inlet.
Offline rockmonkey69
« Reply #3 on: 11 June 2012, 21:17 »
In short no. Keep it before the throttle body.
You can purchase map sensor flanges ready to weld in or sections of pipes already welded with map sensor flange, I think Forge sells it too.
Offline Lewis1.8t
« Reply #4 on: 11 June 2012, 21:30 »
Yea knew forge did one but was hoping to get away with just putting it on the inlet. Any real reason for it not working?
Offline littco
« Reply #5 on: 11 June 2012, 21:33 »
Post throttle sees a vacuum at idle and closed throttle, pre throttle is always atmospheric or positive pressure. Ecu won't like - boost... Has to be before.
Offline Lewis1.8t
« Reply #6 on: 11 June 2012, 21:46 »
Yea that makes sense mate fair doo's better get the forge pipe. Cheers for the help.
Offline littco
« Reply #7 on: 11 June 2012, 21:52 »
Also needs to be after the sic or Fmic as you will always get a pressure drop through an intercooler so the near to the throttle you can get it the better the result, if you for arguments sake put it by the turbo outlet you could experience upto 10% difference in pressure between there and throttle thus causing a rich condition...
