Author Topic: Fog Light Cold Air Feed  (Read 4981 times)
Offline Screech16v
  • MK3 20vt AGU
Re: Fog Light Cold Air Feed
« Reply #20 on: 12 June 2012, 19:17 »
Ive got the lower ducts also ,was worried at first about water intake but having driven through lots of pretty bad weather and heavy spray off hgv,s i worry no more,just dont go wading!
Offline jamesblonde
  • VW Golf Mk4 Estate 1.6 16v Tornado Red
« Reply #21 on: 12 June 2012, 22:31 »
I like the look of the fog light ones though :D
Offline Khare
  • The bear that khares
« Reply #22 on: 12 June 2012, 22:34 »
Fog light cold air intake works better as it has a pretty much direct route to the airbox. From the bumper it has to curve upwards a lot which is not as great. With regards to water intake, you need to drive through knee deep water at speed to even come close to getting water up the airbox.
Offline jamesblonde
« Reply #23 on: 12 June 2012, 22:39 »
Yeah i do prefer the fog lamp intake more.
Offline Screech16v
  • MK3 20vt AGU
« Reply #24 on: 12 June 2012, 22:40 »
Fog light does look cool ,knare did you do your impressive dyno run with this mod as to me the entry seems a touch small  :undecided:
Offline Khare
« Reply #25 on: 12 June 2012, 22:46 »
Dyno run was done as the car stands (except I've ported the throttle body since). The entry is 50mm in diameter iirc, which is not huge, but because it's such a straight path to the airbox it is worth putting there.
Offline Screech16v
  • MK3 20vt AGU
« Reply #26 on: 12 June 2012, 22:58 »
Fair play mate,didnt think is was that big tbh,so the way it is positioned it must have some ram air effect at speed :cool:
Offline Khare
« Reply #27 on: 12 June 2012, 23:06 »
Well the fog light casing is funneled inwards, so that helps a lot. Otherwise I would have put an intake trumpet.
