Author Topic: Engine flush on a TDI?  (Read 8052 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Engine flush on a TDI?
« Reply #10 on: 10 June 2012, 19:44 »
Good point Scarr - should have said to only use oils approved for your motor. If that allows you a choice of extended drain then use that.
Gotcha. I learnt something today :afro:
Offline mrapoc
« Reply #11 on: 11 June 2012, 09:23 »
Think its been done quite often. Worth running some cheaper oil to clean it out?
Offline Bandit127
« Reply #12 on: 12 June 2012, 18:43 »
So why do you think it is dirty and need flushing?
If you really want to flush it then use an oil approved for your engine with a new filter. Run it until the oil on the dipstick goes black - probably about 3k miles. Drop it out, replace with an approved oil and filter.
If you are really worried about it - repeat the above and change it when it goes black. Forever. That is the best protection a man (well, his engine) can get - but it is overkill.
Could do with Oilman's opinion here but IMO - a turbo engine would be better protected at the end of its service interval with fully synth oil than running with cheap (non turbo) oil on day one.
So no. I wouldn't put cheap oil in it if it was mine...
Offline Bandit127
« Reply #13 on: 12 June 2012, 19:05 »
Some further reading.
An American article but covers the basics.
http://www.carbibles.com/engineoil_bible.html
The Oilman thread on this forum.
http://www.golfgtiforum.co.uk/index.php?topic=59317.0
Why you shouldn't miss an oil change...
http://www.youtube.com/watch?v=KC-SxrsgEwo&feature=related
