Author Topic: mk4 golf 1.8 k04 forged engine  (Read 13889 times)
Offline rageraver
Re: mk4 golf 1.8 k04 forged engine
« Reply #50 on: 10 June 2012, 19:37 »
im told by prev owen he put a recirc valve on and it didnt run so good so he put the atmopheric one on.... ive removed it as i read on here its not good for it, but then maybe if car was mapped it would explain why it runs better with the atmopheric, wud i be able to tell if it wasnt good if i fitted it?
Offline rockmonkey69
« Reply #51 on: 10 June 2012, 20:25 »
What I meant was that, if your car was mapped to run an atmospheric dump valve then it's fine, I do not mean if it's mapped then it's fine.
Your picture shows that your car still has a mass air flow sensor so clearly it's not mapped to run off a table with only manifold absolute pressure sensor and revs, so your car was mapped to run recirculating only! It's easy for the previous owner of the car to so easily dismiss your questions with "o I did have a recirculating diverter valve but it runs better on atmospheric"
Very likely his recirculating diverter valve spring was the original green one which was likely weak to begin with anyway! Combined with the extra boost after remap it was probably not holding boost. Whereas the atmospheric dump valve was new and probably had a stiffer spring. Clearly he misconstrued this as the solution.
« Last Edit: 10 June 2012, 20:32 by rockmonkey69 »
Offline rageraver
« Reply #52 on: 10 June 2012, 20:29 »
i agree ill fit forged recirc one when i got the money, if theve got a standard one at the scrappy shall i grab that and fit it in the meantime, i will de chav this car lol
« Reply #53 on: 10 June 2012, 20:34 »
A standard diverter valve will do temporarily, but unlikely to hold at remapped boost levels for a prolonged time.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #54 on: 10 June 2012, 21:19 »
Some Chinese copy K04-001s have the silencer
Offline rageraver
« Reply #55 on: 10 June 2012, 21:23 »
it was an ebay recipte like £280 brand new
Offline Toby
  • Car - less
« Reply #56 on: 10 June 2012, 21:29 »
So when u say the engine is forged?? Any receipts for that?
Currently down under
Offline rageraver
« Reply #57 on: 10 June 2012, 21:43 »
yep gen  recites for parts and from garage with the reg and everything, and another recite from same company for fitment of port and polished head, just over 2k all together
Offline littco
« Reply #58 on: 10 June 2012, 21:49 »
So the prev owner Spent all that money on a forged engine with ported head and then fitted a knock off turbo! Sweet Jesus.....
Offline rageraver
« Reply #59 on: 10 June 2012, 22:14 »
lol tell m about it... recipte does say k04 001 or sumthin like that, be a peach once i finished lol
