Author Topic: mk4 golf 1.8 k04 forged engine  (Read 13860 times)
Offline rageraver
Re: mk4 golf 1.8 k04 forged engine
« Reply #10 on: 09 June 2012, 20:20 »
hey im new to all this,
 i removed plastic engine cover, and i found the n75 valve is not present and the 2 pipes are joined together.
i also found which i think is wrong and have changed, that the actuator pipe was fitted in the air intake pipe ( kandn filter than the maf sensor i guess then there is a nipple in the pipe were my actuator goes to) i have removed this and fitted it so it is on the intake manifold after the throttle body.. i think what ive done is correct as now it shud be reading intake pressure not air in pressure.
so basically now there is no mbc and no n75 valve its just running actuator pressure ( im right arnt i) it now seems to come on boost alot earlier and is maxin at like 6-7 psi which i assume is what actuator is set at.
please help me get this goin right as its had all the money spent in the right places just been piped and messed with by a idiot i guess.
what boost wud be safe limit. if i have to use the mbc, also i cudnt find the electrical connector for the valve???
i also have a recipte for a n75j valve but it must have been removed by prev owner to fit the mbc wich now also is removed
Offline rageraver
« Reply #11 on: 09 June 2012, 20:26 »
also said to be running 230 when i brought it... i would believe this from the previouse owner ( the one who spent the dollar) but now its been messed with
Offline rageraver
« Reply #12 on: 09 June 2012, 20:29 »
also  it has no dmp valve but i have been given a bailey valve to fit
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 09 June 2012, 21:29 »
Holy sh!t mate, get some pics of your setup and we'll try to guide you as to what the pipes should look like...
The way you've described means the ECU has NO way of controlling the boost even if it sees too much. One surge and you could have one of these
Offline rageraver
« Reply #14 on: 09 June 2012, 21:34 »
yep wat i fort,  could anyone post a step by step of what pipe goes where also wat about this n75 valve were wud the wiring be??
ll get pics tomoz
thats why i set it to actuator as that will only boost it like 7psi max.
no dumpvalve eaither...please help
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 09 June 2012, 21:48 »
I'll get you a pic of how mine looks tomorrow if I get a chance to get out to it
Offline Toby
  • Car - less
« Reply #16 on: 09 June 2012, 21:58 »
Ko4 golf
Currently down under
Offline rageraver
« Reply #17 on: 09 June 2012, 22:27 »
thanks for that not quite clear enuff..
heres a pic i have labeled to show how mine is... please help lol....hope it clearenuff
Offline Toby
  • Car - less
« Reply #18 on: 09 June 2012, 22:43 »
Looked like a bodge tbh, sure it's a ko4?
Standard tip ??  :huh:
Offline rageraver
« Reply #19 on: 09 June 2012, 22:46 »
yep def ko4 have all reciptes everthing. was good till the last owner had it was all done good then his mate f**ked  with it
