Author Topic: mk4 golf 1.8 k04 forged engine  (Read 13850 times)
Offline rageraver
« on: 09 June 2012, 01:36 »
hi guys i just picked up  a golf mk 4 with a k04 turbo huge intercooler and full system, the boost dosent come in till 4k and then it pulls like a train, is this normal, when i asked the guy said i had it an econmy map done so it dosent boost till late, he has given me a mbc is there anything i can do to get it boosting early, i thought is shud start around 2.5k can i fit the mbc and remove the n75 valve ( thats if it isnt already removed and just running actuator.
Offline JimBR
Re: mk4 golf 1.8 k04 forged engine
« Reply #1 on: 09 June 2012, 10:09 »
NO! Bin the MBC. A K04 should be boosting before 4k I think.
Check all boost and PCV hoses then get it to R-Tech for a proper map. Do not remove the N75. You can't just turn the boost up without changing the fuelling.
Offline Toby
  • Car - less
« Reply #2 on: 09 June 2012, 10:42 »
Mine comes on boost around 2/3k
Currently down under
Offline dom
  • Back in a Mk4
« Reply #3 on: 09 June 2012, 11:09 »
This. A MBC is asking for trouble.
Sounds to me like a better map is needed :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 09 June 2012, 11:25 »
Manual boost controllers can be fitted with the N75 but must be left alone once set by a pro
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #5 on: 09 June 2012, 11:30 »
Is there just a sh!t load of lag from a 'huge intercooler'? How badly to these things lag? :undecided:
Offline scarr89
« Reply #6 on: 09 June 2012, 11:32 »
How much power you got under the hood? Any RR read out? You and Toby could become best of friends...Ko4 friends  :grin:
Offline Ashmond
  • Money, b!tches And Boost
« Reply #7 on: 09 June 2012, 12:07 »
Same, like late 2's, early 3's
Offline rockmonkey69
« Reply #8 on: 09 June 2012, 14:05 »
varies from wheel to wheel and clipping the turbine wheel 7 degrees slows the spool by ~500rpm but helps with surging.
Just take it to a competent tuning company and have it checked, odds are if your hybrid has a (5304-120-5018) turbine wheel clipped in a k04-022/23 turbine housing 4000rpm full boost is right. You don't want to make an uninformed decision and remove the n75 to stick a mbc on just because you think there might be something amiss...
« Last Edit: 09 June 2012, 14:09 by rockmonkey69 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 09 June 2012, 14:29 »
and then worst case... BOOM
