Author Topic: Rolling road v on road mapping??  (Read 8851 times)
Offline dan2252
Re: Rolling road v on road mapping??
« Reply #30 on: 09 June 2012, 00:55 »
i think mk4 gears a quite short tbh 4th is around 120? most cars can pretty much top out in 4th gear second is around like what between 55 and 60 which isnt that long. there too short if you ask me
MK4 golf 1.8 turbo agu :)
Offline Chris.
« Reply #31 on: 10 June 2012, 21:44 »
MIne was:
1st: 45mph
2nd: 75mph
3rd:100-110mph
4th: 130mph
5th:145mph+
Click For Build Thread
Offline dan2252
« Reply #32 on: 11 June 2012, 00:14 »
75 in 2nd? what box was you runiing? thats mega high! or was your speedo way out? haha :)
Offline Chris.
« Reply #33 on: 11 June 2012, 07:53 »
ENJ. Did it with ease lol.  18" wheels if that matters
Offline tshirt2k
  • Been there...Done that...
« Reply #34 on: 11 June 2012, 11:06 »
Its close. 1st and 2nd are a bit optimistic but that would mean  revving to over 7k to get near that. Not sure if the 1.8T runs out of puff at high revs in high gears though so may not actually get there due to aerodynamics also.
ENJ is the same as a Mk3 16v box. The 18" give it longer legs.
Mk3 ABF 16VT Megasquirt V3
Offline Chris.
« Reply #35 on: 11 June 2012, 11:54 »
Got a video of it somewhere.  I'll dig it out tonight
Offline shaft69
« Reply #36 on: 11 June 2012, 17:32 »
Ive seen his figures 'claims' of 245bhp, but have yet to see a graph showing the power.
Id much rather have R-tech do all my mapping on their rollers.  Even a run in 2nd would push you over the legal limit unless your on the motorway.
He's got bigfish roller print out and has had it on awesomegti rollers made 243hp and 275ftlb there so its close.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Chris.
« Reply #37 on: 11 June 2012, 18:42 »
2nd -5th:
1st-2nd 0-60 hitting 1st off limiter for a while:
Offline tshirt2k
« Reply #38 on: 11 June 2012, 20:45 »
So that's exactly what my calculator said. 1st and 2nd around 5mph too much.
Is that on 225/40-18?
 Speedo possibly over reads a bit too. Good for 0-60 less gear changes. :afro:
« Last Edit: 11 June 2012, 23:07 by tshirt2k »
Offline Chris.
« Reply #39 on: 11 June 2012, 23:00 »
Definately shows the 45mph, 75mph speeds on the clocks.
225-40-18.
Probably works out a few mph over on speedo than in real life?  Still not too bad though :)
