Author Topic: Why you should only use a space saver as "Tempory use"  (Read 2469 times)
Offline tshirt2k
  • Been there...Done that...
Re: Why you should only use a space saver as "Tempory use"
« Reply #10 on: 07 June 2012, 09:00 »
The nuts slackened off the inner shaft with it being a smaller wheel and it being under extra pressure with it being lowered i think caused it. A.d yeah that bit is the speedo drive
Thats rubbish. A wheel has nothing to do with that. The driveshaft bolts must have been loose. If anything it could have worn wheel bearings
« Last Edit: 07 June 2012, 09:05 by tshirt2k »
Mk3 ABF 16VT Megasquirt V3
Offline CJA321
« Reply #11 on: 07 June 2012, 10:09 »
over 800 miles it really does make a differance. Funny how it didnt happen for over a year/10 000 miles since engine was dropped in. Iv never seen it happen before personally nuts just slackening off on inner driveshaft. Thats my thereory and im sticking to it, not that it actually maters.
« Last Edit: 07 June 2012, 10:15 by CJA321 »
