Author Topic: what colour should the coolant be?  (Read 10708 times)
Gavv8
Re: what colour should the coolant be?
« Reply #20 on: 05 June 2012, 19:39 »
Is there a genuine technical reason for this or just because VW want you to buy their own brand.
Yes, the blue stuff can overtime eat into the alloy and cause issues.
Not quite right.
In laymen's terms colours are the same basic fluid, blue and green use different inhibition to Red. Red is long life 5/6 years 100k miles that sort of range where blue is two years.
Its when the inhibitors break down that you get cathodic/granular corrosion in Ali and rust in ferrous engines.
Never mix blue/green/red as the inhibition and other additives are not compatible and will make it useless :grin:
Ok i'll replace it with G12 at the next change but the blue in mine is only a year old so i'm not bothering with it just yet.
VW BUSH
« Reply #21 on: 05 June 2012, 19:58 »
Not quite right.
If its still blue and clean then it will be fine for now
Offline Bandit127
« Reply #22 on: 05 June 2012, 20:13 »
Yeah, but when it goes cloudy it will be due to particles of suspended aluminium, gaskets and seals.   :shocked:
After reading this thread I would probably put G12 coolant on the to-do list (if mine had blue) and time it with a job like a cambelt change.
Luckily mine is pink though - and my list is long enough as it is...
Offline Khare
  • The bear that khares
« Reply #23 on: 05 June 2012, 20:23 »
Wow I wasn't aware that off the shelf coolants were so bad. Will deffo use G12 pink from now on.
VW BUSH
« Reply #24 on: 05 June 2012, 23:38 »
They are not bad if they comply with BS 6580 (1992)
Gavv8
« Reply #25 on: 06 June 2012, 05:37 »
Pure scaremongering.
Offline GTIANNIVERSARY16V
« Reply #26 on: 06 June 2012, 09:23 »
I had a leak.... Ive been topping up with all kindsa sh!t.
Ive got a 1.5 litre G12 bottle now, will that be enough to fill once i drain?
Offline mrsaunders
« Reply #27 on: 06 June 2012, 09:48 »
Last time I done mine it drank 7litres
« Reply #28 on: 06 June 2012, 10:16 »
No way?? I gotta buy 4 more bottles of g12? To inevitably have a leak anyway??
Offline kahunajb
« Reply #29 on: 06 June 2012, 10:35 »
You dilute it 50/50 with water however as it is summer I would just use water until your leak is fixed however don't leave it too long as it is also a rust inhibitor.
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
