Author Topic: Leon Cupra 1.8t No Boost......THERMOSTAT STUCK SHUT  (Read 10391 times)
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Leon Cupra 1.8t No Boost......THERMOSTAT STUCK SHUT
« Reply #10 on: 10 June 2012, 14:00 »
on the passat i found the valve head from the wastegate had fallen off,    somehow found it's way into the inpeller houseing and jammed it up nicely
I have normal boost when it cold its only once it warms up it dissapears so its not a turbo related problem. Got a coolant sensor, thermo, crank sensor and bosch dv on its way which will hopefully cure the problem.
