Author Topic: just a quick report on the VR6 front splitter (cheap ebay)  (Read 4524 times)
Offline murraymint
The material they use is full of re grind and a load of black masterbatch, the genuine parts are the correct grade of material designed to take impacts and resist cold/heat and UV.....
If we could find out where they are moulded then I could supply the right material for a group buy.........
That be AMAZING! would you be aloud on a legal note tho? otherwise all the cheap ebay ones would be doing this?
The eBay ones are made using the cheapest materials possible, for profit not for durability
josh
Gavv8
Cheapo Vr splitter fitted tonight and was really easy, old one pulled off and new one slotted straight on although i think i'll put a couple of self tappers in underneath because its not quite as snug as the old one.
« Last Edit: 22 June 2012, 20:35 by Gavv8 »
Offline Screech16v
  • MK3 20vt AGU
Looks better gavv, my first ebay splitter was a loose fit and popped out one side now and again but my latest one was quite difficult to get on and a real good fit so they seem to vary alot .
Gavv8
Yeah, i read a couple of threads and wasn't expecting miracles but it actually fits quite well although i don't expect it to last long but seeing as i only have a -40mm drop on the front it might be ok.
Offline search
6 WEEKS!!!!
visiting a friend who lives on a farm i split my splitter soooo many pot holes on the way through the filed
anyways went to his to lower my car all the way down but not sure if i wanna get a vr6 splitter again or keep the CL one. what do you people think. borrowing his arch roller to so will be rolling my arches over the weekend.
« Last Edit: 20 July 2012, 20:58 by search »
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline mrsaunders
vr6 one looks alot better, get another cheap one while you source a genuine
Offline 67buggers
I'm ditching my vr one in favour of a gti one mainly because when I remove my helper springs it won't have enough room  :smiley:
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Gavv8
Bashed mine several times already and it seems to be ok..
Offline tshirt2k
  • Been there...Done that...
Dont speak too soon. Only a matter of time.
Mk3 ABF 16VT Megasquirt V3
Offline Shady Pioneer
  • graphic designer.
VR6 one is a lot nicer but you need a genuine one for sure. My Anni has a genuine one with two cracks in it but still going strong!
