Author Topic: Ignition amp heatsink ???? Help!!!  (Read 1744 times)
Offline bigmarky
« on: 30 May 2012, 17:08 »
Any ideas in where I can get a heatsink to mount my new ignition amp on, the old one was cable tied out the way since its got an induction kit and im trying to remount it properly but wanting to mount it on a heatsink wondered if anyone else had done this and where they got one from ???
Tornado Red, 99 AGU, full milltek, K & N, forge007p, 18\" A8 in custom Matt Black with Anthracite inserts, Custom remap, 22psi boost, HID\'s, full led\'s, bodykit.
Offline richw911
Re: Ignition amp heatsink ???? Help!!!
« Reply #1 on: 30 May 2012, 17:16 »
Just done this with my classic mini - applying heaksink compound to the back of ignition modules is a very good idea it helps stop the heat frying the internals  :smiley:
See here http://www.maplin.co.uk/high-thermal-conductivity-heatsink-compound-33695
« Last Edit: 30 May 2012, 21:13 by richw911 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 30 May 2012, 20:17 »
You mean the one that plugs the airbox? I have one spare if you need it
Offline daz veedub
  • Operation 1.8t bolf
« Reply #3 on: 30 May 2012, 20:23 »
cabletied mine to blackbox behind airbox had no issues  :smiley:
u could always run a cold air feed on2 it  :grin:
Offline bigmarky
« Reply #4 on: 30 May 2012, 21:13 »
Yeah that's the one, the last owner clearly didn't give a sh*t and the end result fried my amp so don't want the new one to go down the same route!!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 30 May 2012, 21:21 »
do you want it then
Offline bigmarky
« Reply #6 on: 30 May 2012, 21:41 »
do you want it then
If you don't mind mate?? I've looked all over for something else to do the job and stumped so would be ideal.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 30 May 2012, 21:49 »
will grab it out of the shed tomorrow and PM you
Offline bigmarky
« Reply #8 on: 30 May 2012, 22:19 »
Cheers Wazzzer
