Author Topic: Engine check light????  (Read 2141 times)
Offline daz veedub
  • Operation 1.8t bolf
Re: Engine check light????
« Reply #10 on: 03 June 2012, 20:38 »
Yeah mine is an agu daz, i'll have a look later and see which one will run higher boost then do away with the controller.
replace the boost controller for the same lettered n75 on urs already if ur getting codes for faulty maf your best looking in that direction 1st
Offline daz veedub
« Reply #11 on: 03 June 2012, 20:41 »
A bad maf will cause you to be in limp mode (low boost) as well.  unplug the maf See if it improves. If it does you know thats the problem, but don't drive with the maf disconnected for too long
