Author Topic: Landrover 90- new engine time!  (Read 73255 times)
Offline shepgti
Re: Landrover 90- new engine time!
« Reply #130 on: 04 June 2013, 07:38 »
Will definitely have a look into that nearer the time dh, cheers
Mean while here's the New lump ready for a service
Lifting a 1/4 ton engine out a van onto a stand is not the easiest thing to do!  :laugh:
Offline Screech16v
  • MK3 20vt AGU
« Reply #131 on: 04 June 2013, 23:17 »
Real good work mate,should fly along with that 200 in .
Offline shepgti
« Reply #132 on: 08 June 2013, 22:55 »
audience approved
Offline shepgti
« Reply #133 on: 18 June 2013, 22:55 »
coming along nicely now, engine is all hooked up to the gearbox, fuel lines are hooked up bar blanking one of that's not needed now. electrics were 'fun' but are all sorted and it's cranking which ment undoing the crank bolt was a bit easier.
timing belt and tensioner changed
old
New
the old belt looked fairly new so hopefully that's a sign the engine has been looked after!
still to do- hook up the New custom down pipe, connect up the pas pipes, lower the rad mounts on the front x member, hook up water hoses and turbo intercooler hoses.
hoping to have it running this weekend!
Offline Bellend
« Reply #134 on: 19 June 2013, 10:20 »
Looking good. The whole crank the engine trick scares the hell outta me for timing belts. :grin: I guess nothing can go wrong if there's no fuel though!
Where all my moneys went.
Offline Egbutt Wash
« Reply #135 on: 22 September 2013, 23:45 »
How's it getting along then?
« Last Edit: 23 September 2013, 13:57 by Egbutt Wash »
Currently digging a bunker.
