Golf mk3
hardmonkeys
can i just remove the exhaust heat shield?
Topic: can i just remove the exhaust heat shield? (Read 3481 times)
Screech16v
MK3 20vt AGU
Re: can i just remove the exhaust heat shield?
Reply #10 on:
25 May 2012, 19:54 »
Not sure how much it is as i had it from work but make sure you get the proper stuff as ive known people try and use plumbers lagging which looks similar but will set on fire .
Gti_Jamo
1991 Corrado 1.8 G60
Reply #11 on:
25 May 2012, 19:56 »
If its the tunnel heatshield i would just take it off and heat wrap the exhaust like what I have done in my build thread. The shield just causes rust to form in the tunnel area. Your fuel lines are well out the way.
97' Mk3 Golf Gti 2.0 8v Rebuild Project
http://www.golfgtiforum.co.uk/index.php?topic=208865.0
Golf mk3
hardmonkeys
