Author Topic: F*** Got A Hole In The Blooming Floor !  (Read 2174 times)
Offline Itteh
  • Built Not Bought
« on: 23 May 2012, 00:33 »
Lad's Im Stuck ! Iv just realised that iv got a hole in the rear drivers side footwell. My Carpet was soaked in water. The hole is near the petrol tank, could i get it welded ? or is that too dangerous incase the petrol tank blows ! ??    :sad:
Offline tweed
Re: F*** Got A Hole In The Blooming Floor !
« Reply #1 on: 23 May 2012, 06:23 »
You need to cut out all sh!t metal then weld a plate on. Will have to remove fuel tank and carpets etc.
Offline Itteh
  • Built Not Bought
« Reply #2 on: 23 May 2012, 19:13 »
Bugger, need to spend more money now :(
Offline tshirt2k
  • Been there...Done that...
« Reply #3 on: 24 May 2012, 07:15 »
Common place, it usually the plastic bungs that cause it. Doubt its near petrol tank as that would be in the boot floor.
had them on both sides of mine.
Mk3 ABF 16VT Megasquirt V3
Offline trog_nfs
« Reply #4 on: 24 May 2012, 09:21 »
I had a hole in the rear drivers side footwell too, again caused by a stupid bung
Offline Itteh
  • Built Not Bought
« Reply #5 on: 24 May 2012, 16:33 »
mine is under the rear footwell on the drivers side.
Offline mrsaunders
« Reply #6 on: 24 May 2012, 17:19 »
no where near the tank then, had mine done a while back, pretty cheap really
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #7 on: 24 May 2012, 18:54 »
Real easy fix that and any garage shouldn't charge you much to do it although being a mk3 owner like myself investing in a welder and learning the tecnique would be a good move. You would also want to investigate the source of the water leak into the car and prevent any future corrosion problems. Petrol tank is right at the back on a Mk3 so won't be an issue with welding the floorpan.
Offline tshirt2k
« Reply #8 on: 24 May 2012, 22:16 »
One for the drivers side.  :wink:
Offline clancy
« Reply #9 on: 25 May 2012, 10:36 »
dont need to take the tank off, did mine last week its a piece of piss mate so shouldnt cost you much :)
MK3 GTI 16v
