Author Topic: Pre-1960's cars now exempt from MOT  (Read 3366 times)
Offline AudiA8Quattro
Re: Pre-1960's cars now exempt from MOT
« Reply #20 on: 21 May 2012, 21:05 »
All cars should be inspected new or old. Older cars should have an easier test.
MOT's aren't without faults, but generally are a good thing.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #21 on: 21 May 2012, 21:19 »
C 1, and C 2, 80llox you aint that far behind :tongue:
If you can maintain a pushbike, you can maintain a pre 60's car, unless its a 21 :lipsrsealed:
And not to forget that the MOT used to be once every 3 years, it only changed when cars started to use not so robust parts, and poorly built... in general that is.
Thom
« Last Edit: 21 May 2012, 21:27 by Thom89 »
« Reply #22 on: 21 May 2012, 21:33 »
That was in the days that cars were probably as fast as push bikes  :grin:
The reason all cars should be tested is it only takes one to be poorly maintained...
Offline danny_p
« Reply #23 on: 21 May 2012, 22:37 »
saves me haveing to find a set of pistons for a rover IOE engine  for when the ld mans landrover gets put together  :smiley:
all the VW's have gone bar 1.
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #24 on: 22 May 2012, 19:56 »
hmmm the old mans Vauxhall Victor is around this age...
Offline dan2252
« Reply #25 on: 23 May 2012, 23:34 »
seems abit daft. i mean even if you do look after your car you could miss a rust brake pipe or somthing that a tester might see
MK4 golf 1.8 turbo agu :)
Offline Thom89
« Reply #26 on: 24 May 2012, 01:35 »
I think this maybe the whole point! Testers are looking at this tiny minority of cars, and they are sailing right through the test because  of the simple construction of the cars, and the Ministry of Transport are now clearly happy for pre 60's car to be MOT exempt...
Thom
