Author Topic: Excesive fuel consumption/jumpy idle  (Read 2363 times)
Offline ALTERNATOR
Re: Excesive fuel consumption/jumpy idle
« Reply #10 on: 20 May 2012, 21:02 »
Ok, will check coolant temperature sensor. Seems to be a pretty common problem.
If I'm not mistaking it looks like this, right?:
Offline ALTERNATOR
« Reply #11 on: 22 May 2012, 17:26 »
So, a friend of mine has got a 2.0 just like mine for spares :grin:
Already replaced the ECT sensor with the one he had, it didn't influence the engine at all. Still burning fuel like a warship. What else should I replace now that I can get the stuff I need for free?
Was thinking about the fuel pressure regulator :undecided:
Any other ideas? Don't be shy, I can pull everything out of that thing :grin:(except for the MAF, that's missing)
Offline ALTERNATOR
« Reply #12 on: 25 May 2012, 19:29 »
Ok, got the PCV valve from the donor car, also got the fuel pressure regulator...nothing changed :sad:.
Well, at least it manages about 7L/100km at 50MPH constant driving.
I started it up today, just for a ride around the neighbourhood. Kept it under 2000rpm...the MFA said 67.1L/100KM...I'm desperate :sad:
That's just screwed up...I'm starting to get sick of this car...believe me
Offline ALTERNATOR
« Reply #13 on: 27 May 2012, 12:12 »
Found something interesting...
A wire that was leading from the ignition coil to the ECU harness. Now it's not there anymore, somebody cut it, but you can still see where it used to be. Can't really tell why. Maybe the ECU is the fault. Got a replacement one, but can't start the car, the immobiliser keeps stepping in. I guess I should also get the immobiliser. Where is it located on the car?
How can I get it off the car?
« Last Edit: 27 May 2012, 17:51 by ALTERNATOR »
