Author Topic: what oil?  (Read 10596 times)
Offline itavaltalainen
Re: what oil?
« Reply #10 on: 20 May 2012, 16:49 »
Very much agree to regular changes (you should have seen the oil in the poor Endura 1.3 in my gf's Ford KA  :sick: )
Trying to say also that visco does not necessarily have to do with quality (you can find some £hit 5w40s and some good 10w40s with latest MB specs).
Offline xAntiVenxm
Re: what oil?
« Reply #11 on: 20 May 2012, 17:25 »
.. i run 5w30 A1 castrol magnatec in my little fiesta 1.3 and it's worked wonderfully  :tongue: but got that recommendation from the castrol website.
i've put my golf's reg in the castrol site and this is what it tells me:
Recommended: EDGE 5W-30
VOLKSWAGEN
Golf 2.0 GTi 16V
P-Reg
1993 - 1997
Recommended for Engine (P):    EDGE 5W-30    4.0 or
                                                Magnatec 10W-40 A3/B4
   Manual Transmission    Universal 75W-90    (a)
   Automatic Transmission    -
   Differential    From Gearbox
   Coolant    Refer to Technical    6.5
   Brake Fluid    React Performance DOT 4
   Power Steering (where fitted)    Refer to main dealer
   Wheel Bearings    Multipurpose Grease
a.    Capacity unquoted
1.    Service Interval QG1 = Flexible Service Interval (Long-life service). Service Interval QG0/2 = Time/distance dependent interval (non-flexible)
Engine - Miles Max    10000
Engine - Km Max    15000
Engine - Months Max    12
So, Edge 5w30 because that's their expensive fancy brand and they want you to shut up and give them your money, and 10w40 A3/B4 because that's the less expensive stuff that will also suit your car :P
Re: what oil?
« Reply #12 on: 20 May 2012, 17:34 »
That oil I'd NOT put in any car (same with VW LL2)... very low hths that Ford promotes for fuel economy but it does not save enough fuel to pay for the increased wear in the engine...
Offline xAntiVenxm
Re: what oil?
« Reply #13 on: 20 May 2012, 17:46 »
Hmm.. fair point mate. I've not paid attention to hths much before.. suppose i should really  :embarassed:
might swap for something else next time i service the fezzy..
very helpful this forum! learned something new every time i visited lol
EDIT: While we're talking about it, anyone know where to find a list of the HTHS ratings of oils?
« Last Edit: 20 May 2012, 17:53 by xAntiVenxm »
Offline Bandit127
Re: what oil?
« Reply #14 on: 20 May 2012, 17:58 »
This is a good start for anyone interested in oil specs.
http://wiki.seloc.org/a/Oil_Labelling_Explained
High Temperature High Shear is discussed towards the bottom of the page.
I was thinking that my engine never sees oil at 150°C. But - while the temperature gauge might read 90° I have no idea what it is in the cylinder bores and on the cam lobes where it really matters.
Note that Silkolene Pro S has been rebranded.
http://www.golfgtiforum.co.uk/index.php?topic=59317.msg1390036#msg1390036
« Last Edit: 20 May 2012, 18:02 by Bandit127 »
Offline GolfGL
Re: what oil?
« Reply #15 on: 20 May 2012, 18:18 »
On my now sold 1.8t i would.use the very best oil around and something thin to get straight up to the turbo but with my golf i would just put 10w40 in. id steer clear of halfords own but any castrol/mobile 1 part synthetic will be fine and as engines get older id.keep to a thick oil as tolerances reduce as parts wear
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline D Squared
Re: what oil?
« Reply #16 on: 20 May 2012, 18:19 »
thanks for comments guys... till present i have given it a change of oil once a year, after around 8000 miles a year, and have been using VW spec LL2 (as it was free..).. was think of using 10W 40 as a few of you have mentioned.. so may try either the Castrol GTX or Millers stuff..
MK3-MK5- Now MK7 GTi
Offline xAntiVenxm
Re: what oil?
« Reply #17 on: 20 May 2012, 18:24 »
i'm assuming different brands of the same grade oil will have different HTHS ratings? don't see many HTHS ratings published, will read that wikipedia page and see if it doesn't explain how to determine it from other stats of oil
Re: what oil?
« Reply #18 on: 20 May 2012, 19:28 »
HTHS cannot be determined from other oil specs as such, it has to be measured with a viscometer or rather a rheometer... So if unsure just buy one (they are >30k though).  :tongue:
Joking aside, hths is usually in spec sheet (maybe labelled as visco at 150), along with visco at 40 and 100 °C, TBN, pour point, etc
Google usually does a good job locating those, otherwise email the manufacturer or distributor.
If uncertain what to buy, make sure it's ACEA A3/B3 or A3/B4 and then look for VW 502.00 (petrol), if it has that it's usually already useable, better still if it actually has MB 229.5, that's currently the most strict norm when it comes to cars (except 229.51 which only matters if you have a particulate filter). If you are running a Diesel the equvialent would be 505.00 (but LOADS fulfill this old standard, so not really an indicator), or 505.01 if it's a Pumpe-Düse = usually refered to as PD TDI.
Oils with VW502.00 usually are 5w40, 5w30, 0w40, a very few 0w30 (but then these aren't usually LL2) and even a few good 10w40s.
