Author Topic: Pictures of my airbox, show me where to drill!  (Read 4551 times)
Offline Chris_D
  • www.hijackbristol.co.uk
Re: Pictures of my airbox, show me where to drill!
« Reply #10 on: 08 June 2005, 21:52 »
ok, all drilled, this is where i've done it
Offline Organisys
  • Old and Slow...
« Reply #11 on: 08 June 2005, 22:14 »
Get a K&n Panel filter too, if you havn't already. I also put some gauze inside the box, just to stop bits of leaf or any other junk getting onto the face of the filter.
mix
« Reply #12 on: 08 June 2005, 22:21 »
Shoot it with a shot-gun from a distance to get maximum effect :laugh:
kingsmk2
« Reply #13 on: 09 June 2005, 09:48 »
did u locate the trim in the wing???
Offline Chris_D
« Reply #14 on: 09 June 2005, 16:52 »
yeah i got it cheers, a square shaped panel clipped in to the inside of the wing, what about the plastic trim that sits directly behind the drivers side headlamp? can that come out?
kingsmk2
« Reply #15 on: 09 June 2005, 16:55 »
it can but it will leave wiring exposed and could cause issues but its upto you m8
Offline Chris_D
« Reply #16 on: 09 June 2005, 16:57 »
think i'll keep it then, don't want problems i can't fix!
Offline Chris_D
« Reply #17 on: 09 June 2005, 21:35 »
only trouble with these free mods is they don't work out to be free, you can watch the needle go down as you listen to that new noise!!
