Author Topic: Electric Window Mech's - "How To"  (Read 97817 times)
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Electric Window Mech's - "How To"
« Reply #10 on: 03 September 2012, 02:27 »
Great write up, worked a treat thanks!
:afro:
For More Info Click To See;
Offline JamesS
« Reply #11 on: 05 September 2012, 15:26 »
I put a full set of lecky windows in my 5 door when I was doing the engine conversion. I took all of the motors apart, checked and greased them before installing because I had heard they get crusty like this inside. One of them didn’t work so thought the motor was up the creek, I took it apart and magnets looked good and there was no play etc so wasn't convinced it was a gonner (it's a right hassle to put back together thought!). I looked to see how much replacements are and thought chuff that, took it to a local old school HiFi repair man and he found that the resistor on the motor had burnt out, £5 later a new resistor had been soldered on and was as good as new!  :laugh:
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline Steve_B
« Reply #12 on: 23 April 2013, 11:37 »
How did you prise the plastic cog away from the spindle it's on, I'm scared of breaking it if I apply too much pressure
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #13 on: 23 April 2013, 12:01 »
used a small screwdriver and gently prized it off.
Offline Steve_B
« Reply #14 on: 24 April 2013, 22:42 »
That worked with one but not the other, greased around it in the end as I'm sure it would snap before it worked free.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #15 on: 24 April 2013, 22:50 »
Have you tried soaking it in WD40 overnight??? then gently prizing it in 90 degree movements. I had one that was seized like this and got it off with trial & effort but don't force it as you can't get replacements..
Offline Steve_B
« Reply #16 on: 25 April 2013, 10:56 »
Tried that but it still wouldn't budge. In the end I just sprayed loads of grease in the spindle and it span freely when I connected the motor. As you say there's no replacements so better safe than sorry I thought.
Offline HIGGSPEED
« Reply #17 on: 18 November 2025, 09:19 »
photos no longer exist . anyone else got a similar thread ?
