Author Topic: a bit puzzled !  (Read 5010 times)
Offline Jonnybbad
Re: a bit puzzled !
« Reply #10 on: 18 May 2012, 15:20 »
Running 21psi u should really at least uprate the standard side mount they may say its ok but u will notice a difference over the standard 1
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: a bit puzzled !
« Reply #11 on: 18 May 2012, 15:25 »
i can only think there is a split in one of the pipes that is going to the n75 valve, check all these.....
have you changed/checked the pipe that connects to the charge pipe n goes to the n75? think it is hiding in a heat shield.... check all 3 of these anyway!!!
Thanks I will have a look in a min
I just received through the post today the creation motor sport 5 piece silicone turbo boost hose kit, so i am going to fit it all, I think the pipes you are on about are some of those in this kit..maybe, is that right?
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline rio_gti
Re: a bit puzzled !
« Reply #12 on: 18 May 2012, 15:45 »
yeah one of them is, the one on top of the charge pipe to n75.
have fun doung the ic to tb as its a bumper off job!!!
also the turbo to charge pipe is TIIIIIGHT!!!!! (and once you have done this one let me know if there is a different sound when she boosts)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: a bit puzzled !
« Reply #13 on: 18 May 2012, 17:10 »
THS intercoolers retail at £495...
£200 to fit it is a bit extreme though, I'd do it for half that  :laugh:
Re: a bit puzzled !
« Reply #14 on: 18 May 2012, 19:49 »
TIIIIIIGHT ! more like TIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIGGGGGGGGGGGGGGGGGGGGGGHHHHHHHHHHHHTTTTT 2 bloody hours I was messing around with that one!  :laugh:
I am not to sure about taking off the bumper, is it easy? I will do the pancake pipe one tomorrow
Re: a bit puzzled !
« Reply #15 on: 18 May 2012, 22:43 »
Those pipes have made it a lot better (the ones from the charge pipe to the diverter valve, the turbo and the N75 valve). There was a tiny hair line split on the one that went to the N75 valve, and now the car almost feels normal again, well it did earlier when I took my 10 yr old son out and over took a mk4 2 ltr gti golf, and left it way behind me  :laugh: it put a massive grin on mine and my son's face  :grin:
Offline rio_gti
Re: a bit puzzled !
« Reply #16 on: 19 May 2012, 00:54 »
You know!! Told ya  :grin:
Yeah don't be worries it's easy, will take less time that the other one haha
http://uk-mkivs.net/forums/p/122899/830545.aspx
Do this one tomorrow too, and when the bumper is off take the intercooler off and give it a clean out (either with carb cleaner or petrol) as there will be oil in it!!!
Let us know how you get on mate
Re: a bit puzzled !
« Reply #17 on: 19 May 2012, 08:58 »
Thanks for the link  :smiley: I am still unsure about trying it yet, I will weigh it up later with the weather too  :wink: but I will definitely replace the small pipe from the pancake pipe as I can do this buy just taking the wheel off, or if I did take the bumper off, could I do the pancake pipe without taking the wheel off?
Re: a bit puzzled !
« Reply #18 on: 19 May 2012, 22:29 »
I done it  :grin: I feel well pleased that I managed to do it, I cleaned the intercooler with some carb cleaner, a bit messey. It was a bit of a pain getting the intercooler lined up again, but managed it after a bit of pulling and pushing.
The car is most definitely better and the turbo now sounds like a suppercharger LOL. I think I will put the old N75 back on tomorrow, because I put a new J - N75 on the other day, and I think that could of been the cause for the 17963 code that came up.
Offline rio_gti
Re: a bit puzzled !
« Reply #19 on: 20 May 2012, 01:48 »
Nice one!! Glad you got it all done mate, I had to trim that one down for it to fit!!
Don't it make a difference!!?!
