Author Topic: Whirring helicopter sound  (Read 1841 times)
Offline harlemex
Re: Whirring helicopter sound
« Reply #10 on: 19 May 2012, 14:55 »
clutch up would be input shaft bearing.  :sad:
Offline Jin_C
« Reply #11 on: 21 May 2012, 12:38 »
So I'm assuming it is worst case scenario and I need to replace my gearbox. I spoke to VW, gave them my chassis no and they told me I have an ECW gearbox and it should have 108mm driveshaft. (is this the same as driveshaft flange?)
I've done a bit of Googling and another post says that the drive shaft flange is 100mm.
Can anyone tell me if I have to go for another ECW or I could also go for an ENJ since they have the same ratios
Thank you
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
