Author Topic: seised engine!  (Read 4531 times)
Offline stainesy
Re: seised engine!
« Reply #10 on: 18 May 2012, 11:19 »
Ah that's fair enough mate. Wile the engine is not in yet give it a good clean up and service mate and make sure it turns over before you put it in  :wink:
Offline Bandit127
Re: seised engine!
« Reply #11 on: 18 May 2012, 20:37 »
Ok then it probably isn't seised, its been in side an the plugs are still in. Whats TDC?
Ok so got to sort the timing out then. Got ya
Timing will be fine unless the belt has perished and snapped - VERY unlikely and easy to check.
If you want to do the cambelt and pulley before you fit the new engine (and it will be easier that way) you need to get the engine rotated until the timing is right. This is Top Dead Centre on both the crank and the cam.
That is what I meant by 'set the timing' - set the cam to TDC where all the valves are closed - only needed if you are doing the belt.
There will be a guide on here for doing the cambelt and it should be fairly straight forward since there is only one cam and a pulley.
Shout up if the belt is snapped and we can help line up the engine to TDC.
Good luck with the transplant. When are you aiming to get started?
Gavv8
Re: seised engine!
« Reply #12 on: 18 May 2012, 20:47 »
Your changing an entire engine but don't know what TDC is?
Offline Screech16v
  • MK3 20vt AGU
Re: seised engine!
« Reply #13 on: 18 May 2012, 20:58 »
I think he must be the real frank galager  :laugh:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: seised engine!
« Reply #14 on: 18 May 2012, 21:11 »
Has it been lying flat at all?  if so, cylinders will fill with oil, plugs out, and turn over, then crank when its in with plugs out.
If its not that, fill cylinders with coke and leave over night, keep topping it up with more coke,  but remember to change oil after  :grin:   Works for me every time!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline stainesy
Re: seised engine!
« Reply #15 on: 18 May 2012, 21:14 »
that would cost a fortune  :grin: :grin: :grin:
Offline Rmachines
Re: seised engine!
« Reply #16 on: 21 May 2012, 17:32 »
Lidl Cola - Tastes just as good, even more caustic and 29p per 2l bottle  :drool:
Offline CJA321
Re: seised engine!
« Reply #17 on: 21 May 2012, 18:12 »
Was thinking that. Goodluck thou, let us know how you get on!
Gavv8
Re: seised engine!
« Reply #18 on: 21 May 2012, 18:21 »
It'll end in tears.
Offline Bandit127
Re: seised engine!
« Reply #19 on: 21 May 2012, 18:26 »
Just read about another method of sorting rings seized in bores. Start a fire...
http://www.golfgtiforum.co.uk/index.php?topic=35338.msg348231#msg348231
LOL - it seems to have worked.
Quote
It's free'd up nicely and it doesn't look like there's any damage
